Air Ventilation Brick
12 May 2009
Hi. I just stripped of all the paper in my room, and realised it was covering an air vent, which as a result caused mould build up on the walls and near the window. Okay so I know I have to keep this vent clear to prevent the problem from happening again, however I live on a very busy road and keeping the vent slide open lets in a lot of noise from the road. I know this sounds impossible, but is there any way I can leave the vent open to let in the air, and at the same time keep the noise out? If not would it be best to brick up the air vent and re-direct a new one through the loft into the ceiling?
Thank you.
Whats the vent for? If there's no open fires/ boilers/ gas fires in room I normally paper over again, after treating mould with thin bleach. But check first re gas appliances.. :wink:
No gas fires or boiler in the room. I treated mould with a bleach solution before and papered over it last time, but it hasn't worked. The vent is just for air ventilation into the room.
Ok. Well all I can say is brick/block both sides up. Try just blocking the outside temporary with a peice of ply (stick with some painters caulking not no nails :-) ) I reckon the vent itself may be causing the prob Is the vent facing prvailing winds/ rain penetrates.
try for a year and block up permanantly when if no mould/ damp comes back. Thats my view anyhow..
Good luck
Good luck
Yes you're right the vent is at the corner of the house, and is facing wind and rain, however the area where the paper was covering it never got damp. I'll block it up temporarily with with an insulation block, surrounded by expanding foam, and replace the vent cover over it, so it lets in a little air. What is painters caulking? :?: Thanks for your help.
