AirSource
12 Jun 2013
Gwynedd
Hi all
Im just starting off on my self buid home, considering different central heaing systems, currently thinking of going with an air source Mitsubishi Eco Dan, that will heat the hot water and also underfloor heating downstiars and rads upstairs.
Has any one had exoperience of using these air source pumps and how much more expensive they would be compared to oil. The land is just off the Gas conection, seperated by a river unfortunately
Thanks for any advice
They use a lot of electric.
You'll need a wind turbine to run it. The money would be better spent on insulation!
Hi all
You don't own the river do you?? How big is your garden?? Both questions are related to a geothermal heat pump. If it's got to be an ASHP go for Diakin.
They are giving away wood pellet boilers at the moment.
Get it finished quick and then get one installed for free. :-)
I would go with a passive house then you don't need any heating.
Hi all
How do you expect to get enough temperature out to heat rads?
Hi all
It's generally done with larger surface area radiators Tony run at low surface temperatures, with minimum 15mm connections & lots of good circulation. If you keep the Delta T low, you can normally get away without a buffer tank. My preferred way would always be circulation via a buffer though.
