    Dismiss Notice
Alarms Security Alarms CCTV
Discussion in 'Alarms, CCTV & Telephones' started by Kantilal Tanna, 7 Jun 2020.
  1. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    Hello,
    I have Accenta Mini G4 alarm system with keypad with 4 PIR. I had this problem about 3 days ago when you try to set it will not set up and will contiously bleep.
    All 4 PIRS have stopped working and the prog key when pressed it comes with Tamper lock.
    All zones are showing 0000000 not showing which zone has problem.
    I wonder what may have gone wrong.
    Please help.
  2. Sponsored Links
  3. Handymanjo
    Handymanjo
    2 Feb 2016
    1,836
    Thanks Received:
    358
    Newark
    Country:
    Tamper lock out is telling you have a tamper fault, this could be bell box,control panel,or a detector.
  4. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    Thank you Handymanjo,
    Siren and strobe is working fine, but all 4 Pirs does not show any light but I don't know which might have failed.
    Do you think replacing all 4Pirs or Control Panel (PCB) might resolve the issue.
    Thank you.
  5. Handymanjo
    Handymanjo
    2 Feb 2016
    1,836
    Thanks Received:
    358
    Newark
    Country:
    Are the pir's not lighting up when you walk in front of them ?
    If so could be a blown fuse.
    If this is the case then could be possible faulty battery, damaged cable or other issues.
  6. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    Thanks a lot.
    Will have look at fuses and will test with amp meter.
    Highly appreciate your help.
    Thank you.
  7. Handymanjo
    Handymanjo
    2 Feb 2016
    1,836
    Thanks Received:
    358
    Newark
    Country:
    If you are checking fuses are you competent.
    Control panel will have 230volts inside.
  8. Sponsored Links
  9. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    Sorry, I meant, I will have it checked by Alarm Technician.
    Thank you once again.
  10. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    After the Alarm Technician fixed the system which works fine but I have couple of problems.
    1.The Informa Dialler doesn't show any power. Does it mean it is dead? Can it be repaired? Can anyone suggest company or person to repair or look into what is wrong. Please let me have any contact name and telephone number.
    2. The Set button on RKP would not work when you try exist. It works if you press code to set system.
    Please can anyone advise what might be wrong.
    Thank you.
  11. Handymanjo
    Handymanjo
    2 Feb 2016
    1,836
    Thanks Received:
    358
    Newark
    Country:
    What did the technician fix?
    Where these faults present o your system when the technician came or did this start after would ?
  12. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    I explained him about faults and he opened the panel worked out what may be wrong and fixed it.
    The problem with alarm doesn't go into set mode happen and realised that dialler is not working later on.
    I hope there is a solution to resolve this problem.
    Thanks.
  13. Handymanjo
    Handymanjo
    2 Feb 2016
    1,836
    Thanks Received:
    358
    Newark
    Country:
    Did the engineer set and unset the system after fault was diagnosed.
    Call then back if still faulty
    What does it say on his work sheet does it say left working .
  14. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    Ok Thanks. I will do that.
    Any suggestion about what might be wrong with dialler. Can it get repaired?
    Thanks for help.
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
