Alarms
MrS
24 Feb 2006
Are alarms covered by Part P and do you have to be Part P registered to install one? Do they have to be on their own circuit or can you take them off the socket ring or lighting ring?
Am I right in saying that alarm/telephone cable cant be run together with electric cables?
alarms and phones etc are not part P. altho the panel mains wiring will come under part P if it get its own new circuit. i would just spur from a ring main using a FCU with 3A fuse
Unless you are installing it in a special location (as in those in BS7671) where it is part p notifiable.
thanks that clears it up. so if an alarm sensor was to be put into a bathroom it would come under part p becuase a bathroom is a specail location.
can alarm and telephone cables be run alongside wiring cables? do they have to be seperated?
1: alarm wiring itsself does not come under part P. just the wiring to the panel will if its either got a new circuit or its in a special location
you should try and keep alarm and power cables seperate. at least 50mm to avoid interferance. more noticable in phone lines than alarms tho, but it can bring up some interesting faults
