ALDE COMPACT 3000
  • Thread starter Thread starter BQW
  • Start date Start date
BQW
15 Apr 2008
Isle of Wight
Has any one experience of changing a Over Heat Stat on a Alde Compact 3000 Caravan water heater, how easy or hard is it ? the heater is located underneath the front seats, looks like access could be a pain.
Stat keeps popping out but water is the correct temp.
No experience at all, but a bit of research suggests it might be due to the combustion fan being faulty..
I understand your thinking, but she told me she only runs it on electric !
So either the overheat trip, is tripping at too low a temperature, or the normal stat is failing to switch off at the correct temperature.
If the latter is adjustable, she could try as a temporary fix, turning that down a touch.
