Hi guys,
hope you can help, I came home after a week to find my flat with a large wet patch under the bolier, I immediately opened the cove to check, I noticed dripping from the left side bottom, see pics, its a small plunger that activates a small black switch when the hot water is turned on and goes back when turned off. Water is emerging from around the pin hole, its a constant drip. What is this part called and any idea on how to replace this part?
Any pointers would be very greatful,
thanks in advance..
thanks in advance..
