Alpha 240E diverter valve leaks only when there is a demand for DHW. do we need to replace the whole valve or just the front part of it (DHW flow valve)
It looks similar to whats been used in other boilers made by Gianonni (I think) this kit is what you should need and this thread should help with the repair
Good evening. My elderly baxi 105e drips from between the pressure differential valve and the Bush nut that connects it to the rest of the diverter valve. I think it only happens when I'm using hot water. Any ideas what to replace?
