Alpha 240P Hot water ok but NO central heating
3 Apr 2008
London
I have changed clock timer, but the central heating is still not work.
No light, no noise, no pumping, nothing happens after I switch to CH.
Is it going to be the main PCB problem? :(
I assume you changed the clock BECAUSE it was not working?
Have you got a room stat? If so that could be at fault.
Most likely to be a simple external fault !
The PCBs are quite expensive so everything else should be eliminated before changing the PCB!
Tony
