alpha 280e gas boiler
17 Jun 2011
Derbyshire
When I turn on the hot tap, the gas comes on to heat the water, but after the initial heating the gas goes on and off.
It gives a few seconds of hot water, then a few seconds of cold, then hot, then cold, so on and so on.
dirty plate heat exchanger is the usual cause, clean or replace - system will most likely need a clean too.
