Good evening all,
We have just moved into a property but found we have no hot water from our Alpha CB24 boiler.
The central heating works fine but even when it's running the hot taps run cold. I have done some diagnostics but am now stuck...
- There is 24v across M5 terminal 16 and M6 terminal 20 on the main PCB,
- The DHW switch works when it is removed from the boiler (i.e. the burners fire when the switch is released and cut out when the switch is manually operated) but not when it is installed in the pipework.
Even when the switch is operated outside of the boiler pipework the hot taps still run cold.
This is leading me to think it is an issue with the diverter valve but I have no way of confirming that, does that sound likely given what I have described?
There is also a leak from the union between the DHW heat exchanger and diverter valve (it looks to be coming from the joint itself).
Many Thanks
Dan
Many Thanks
Dan
