Hi folks, I am having a problem with my Alpha CB28 Combi.
It has only occured within the last month or so.
When I run the shower, a manual mixer, the boiler fires up fine. It will stay alight for varying amounts of time and will turn off. It then fires back up again within about 10-15 secs.
Obviously during this interval the shower is then running cold until the boiler fires up again.
The pump is running fine, the divertor valve and diaphram are ok, although I changed these as precaution.
I have also changed the DHW heat exchanger and DHW sensor. I have an identical spare to source parts.
I have tested the DHW stat and I 'think' am getting the correct readings according to the handbook, less than 1 Ohm continuity across the terminals.
I have changed the shower head as I thought it might not be letting the minimum of 2.5 litres per minute through, although there doesn't appear to be a drop in pressure, now I am thinking of changing the shower, never liked my one anyway.
Sometimes if you leave the shower running for say 15 mins, the boiler will stay on and all is well.
I am going to see if these problems occur when running a bath or basin / sink taps, which would suggest the theory of not enough water flow, but your help or ideas would be appreciated.
