I have an alpha ocean 280P boiler. The hot water to each basin/sink in the house (4) continuously runs hot as does the bath tap. However when you use the showers (2) where both the hot and cold taps need to be running on the bath the water fluctuates between hot and cold without altering either tap. This situation also occurs with the other shower, a mixer shower which states on the manufacturers instructions that it is OK to be used with a combination boiler such as mine. What occurs is that the main burner fires up to heat the water and after about a minute it goes out for about 15 seconds and then fires up again bringing back hot water before repeating the process of going out, but after only about 30 seconds subsequently, and then coming back on again. So the water fluctuates from very warm to very cold continuously. The service people tell me I need a new Heat Exchanger which is not covered but if this is the case why does the hot water remain constant when it comes from the hot tap only. Any thoughts will be appreciated.
