Potterton Kingfisher Rs60
Am I allow to take the boiler heater exchanger out and give it a good clean inside as I don't have to touch the gas side as it's not connect it to the casing? If not, then Plan B whatever that is
I have put in sentinel x400 but the water came out clean after 4 wks, then I have put in Fernox DS-40 for the last 7 days which I have drained down today and came out dirty black/brown water but it's still pumping over to the F&E tank after 10 mins. It's okay when the boiler stat is on minimum temperature as it doesn't pump over as this is my temporary plan at the moment. My theory is the boiler casing is boiling because of less water inside the casing therefore it's start boiling turning it to steam to the F&E tank.
I'm now thinking I have a restricted flow in the boiler exchanger hence why I want to have a look the internal casing it if that I'm allow to do it
I've still got the manual and it's quite simple to do. Having said this, the Fernox DS-40 does say on the instruction "Repeat doses of DS-40 may be applied where necessary".
I appreciate anyone helping on here but must be corgi registered for me to accept the answer correctly, thanks.
PS, I have renew some pipe work where I can including the feed T-Piece.
