We pay about £50 for a m3 in bags, or £40 ish loose. Try a decent turf supplier for it, it will be cheaper than a builders merchant.
Let it dry out a bit definetly. If you are going for the sandy loam, you basically want it roughly level before you put it on, so rake it and break down the big lumps. The loam will cover a multitude of sins.
No apologies necessary, dont ask and youll never understand. Basically it means getting it flat by use of pulling a staright edge over it. WIth the sandy loam the way we do it is as follows
KEEP IT DRY FROM DELIVERY, UNTIL ITS BEEN LAID! sorry to shout, but that is vital. if its wet when they deliver it, tell them to stick it, its an useable mush then.
Barrow it onto the lawn area and leave it in small piles dotted about.
Rake it out to get it roughly level, by eye.
Walk across all the lawn taking pigeon steps to get it lightly compacted (no rollers or anything else)
now lightly rake it to break up the surface of it again.
The point of screeding it is to have a nice flat surface to roll the turf onto. you dont want to be walking over it once its been done, so work out where your start point for laying the turf will be. (in the pictures you can see we started laying the turf by the paving and worked off of boards, so we finished screeding by the paving)
get a peice of straight timber (its better with 2 people and a longer bit) and draw it across the surface of the loam. that will give you a flat surface. fill in any dips as you go. Work your way back towards your start point for the turf laying. thats the screeding bit!
Now when you lay the lawn, do as you can see and work off of scaffold boards, planks of wood or whatevre you have. The loam will be soft and if you walk on it will give you footprints in the turf. It needs time to settle and compact after its all been laid. Dont worry about trying to get stripes on the lawn when you lay it by the way, its just the way the turf is rolled out, it doesnt affect how it looks later on!
hope that helps!
