Go a pair of 178x 102 beams on order to support my solid 9" gable end. Been busy prepping today knocking out some bricks above so I can support with props for when I cut out the bricks to place the beam in. Can access from the side so it can just be placed in rather than thread through a wall.
My bricks are 75mm imperials with a 10mm mortar joint. If I remove 2 bricks and the associated mortar, this gives 180mm - The padstones are set 5mm below which would leave a gap of 185mm to slide the UB in.
Am I asking for trouble as I'm leaving myself a 7mm wriggle room? Keen to avoid taking a 3rd brick out above as will be a pain to squeeze them back in after installation.
