would 11.55kg dunlop 2 part rapidset flex cover 3 sq metres hope so, it costs enough thanks P M
It depends on how true the wall is, how big the tiles are, and how thick a bed you use. If the wall is very bad and you're having to load it up to get a flat surface then 11.55kg isn't going to be enough.
Why not just get another bag and take it back unopened if you don't use it?
Er, I would buy it from somewhere else then.
What is the flooring material you want to tile on that makes you want to use 2 part flex?
