amptec boiler problem
22 Oct 2011
Dunbarton
Help!!! I have an Amptec 11Kw electric boiler installed, the problem I have is it never turns off unless I isolate at the 45 Amp switch. The pressure is at 1.5Bar, the pump is running, could it be my expansion vessel not set properly?? The boiler stays on even when the room thermostat temperature is reached and even when I put the control panel to off.The wiring has been checked and the system is wired correctly. I'm at my wits end. Any ideas ????
Yes I have a 3 port valve fitted and a bypass valve, I've checked the operation of the 3 port valve and it is working when I switch between heating, hot water and a combination of both. The bypass valve is currently set at 4, there is no knocking noise from the system.
A capacitor is required.
If the person who 'checked the wiring' and/or installed it was any good, they would have known this.
Thanks very much, I'll get in touch with the guy and politely point this out. Is it a big job to do? and how much will the capacitor cost me, I dont want to get ripped off :D
