OK temperatures have dropped and therefore reminded me that I should have improved insulation in house last year!!!
1955 Bungalow with a Lounge built over a garage and an open stair case leading up to a roof conversion bedroom. The bedroom has a radiator within but an area (landing) outside the bedroom door approx 3m x 2m has no form of heating.
Garage is large but a single with up and over garage door (with lots of drafts) and a concrete roof/floor. Should note that the boiler is located in the garage. Lounge is 3m x 7m with 2 large windows and 2 smaller windows built over the garage. There is NO insulation on the garage roof or between the roof and the joists to floor boards. The space between the two is approx 4" to the under side of the joists which I can see down from under the crawl space under the house. I therefore cannot access easily the space under the lounge.
Crawl space access within Garage (again with drafts) and a door approx 1m square. Leads to rest of crawl space which varies in height under the joist from ~1.5m to < 0.25m
Kitchen is incredibly drafty around non-fixed applianced (washer & dryer) and has a tiled floor. I can access the crawl space under the whole kitchen and the majority of the rest of the house.
I want to improve heat loss from flooring area especially in the lounge and kitchen as these seem to be the rooms which suffer badly for being cold.
Challenge 1 - Under the kitchen (3m x 4m) I have considered putting insulated boards (celotex??) between the joints but not up against the underside of the floorboards (is this OK to do?) and also perhaps under other areas without carpet I.e. Bathroom Floor (Varnished floorboards 3mx4m) and Hallway (Solid wooden floor over original floorboards 1.5m x 8m).
Challenge 2 - The lounge (carpeted) How can I improve the insulation of this floor given the challenge of the space between Garage roof and Joists. Considered trying to push rolls of fibre insulation down using rods but this would be rested on top of the concrete garage roof. Like wise considered Celotex type boards cut into strips to get through access space! again rested on garage roof. Would this be "acceptable" and likely to improve heat loss?
Also considering the replacement of the up and over garage door with a double glazed type unit to reduce the amount of draft as I don't use the garage for vehicles.
Any recommendations given the information above?
