the feed tank is full, the cold feed !!why doesn't do that when the heating is on?charlieboy3 said:it might be worth checking to see if the f&e tank has sufficient water in it, if this is ok i would suspect there is either a blockage in the cold feed or the boiler stat is not working correctly.
the pump runs only on H and its off on DHW and that as you know the classical system, its not a fully pumped systemAgile said:I think that you should be checking the pump !!!
It its too hot to handle then it is probably not turning! See FAQ.
Tony
OK thanks I check thatcharlieboy3 said:I still think there is a blockage in the cyl primaries, or the temp regulator in the cyl return has stuck(provided you have one)
thanks it was the boiler's statcharlieboy3 said:I still think there is a blockage in the cyl primaries, or the temp regulator in the cyl return has stuck(provided you have one)
Thanks matenamsag said:Told ya so .![]()
