    Dismiss Notice
ANALOGUE RF OUTPUT TO SCART INPUT OR HDMI INPUT
Discussion in 'Audio Visual' started by TIMOTHY HOPKINSON, 9 Oct 2019.
  1. TIMOTHY HOPKINSON
    TIMOTHY HOPKINSON
    8 Oct 2019
    Thanks Received:
    Country:
    TO ANYONE WHO CAN HELP ME I HAVE A VHS DVD RECORDER THAT OUTPUTS THE TUNER CHANNELS MENUS AND DVD/VHS AND SETTINGS MENUS OUTPUT TO A RF OUTPUT THE SCART ON IT ONLY RF OF A FREEVIEW BOX FIRST TUNED IN CHANNEL SET TO THEFIRST CHANNEL INPUT SO IT DISPLAYS THE FREEVIEW CHANNELS BUT ITS CANNOT OUTPUT ANYTHING BUT A RF SIGNAL WHICH MY HDMI HIGH DEF TV DOES NOT HAVE AN ANALOGUE TUNER
    IS THERE A WAY FOR A CONVERTER TO COVERT ANALOGUE ARIEL RF OUTPUT TO SCART OR HDMI INPUT
    ANY REPLIES WILL BE GREATFULLY APPRECIATED
  2. Sponsored Links
  3. Lucid
    Lucid
    10 Sep 2013
    1,688
    Thanks Received:
    975
    Cheshire
    Country:
    Welcome to the forum, Timothy.
    I think the answer to your quest is an analogue TV tuner, but my guess is you're going to have a bit of a tough time finding one. Depending where someone lived, analogue has been switched off in the UK for 7 to 12 years. There are plenty of inexpensive digital TV tuners for sale, but I haven't seen any analogue ones for a long time.
    Your post was hard to read. Try to use sentences. Also, typing with Caps Lock set to On is something we don't do in forums. It's the internet equivalent of shouting at someone right in their face. It's very rude. Please don't do it on your next post, thanks.
    • Like Like x 1
  4. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    3,992
    Thanks Received:
    801
    Durham
    Country:
    You sure there's no output from the SCART ports on the VCR? Some machines had 2 SCART ports, one was in only, (on mine marked decoder), the other was marked TV. Some SCART leads are only 1 way as well.
  5. winston1
    winston1
    11 Jan 2010
    6,491
    Thanks Received:
    494
    London
    Country:
    Also note Ariel is washing powder not a radio/TV receiving device.
    Are you absolutely sure your TV has no analogue reception capabilities? Not seen a TV without yet except odd pocket ones. What is the make and model number?
  6. Rodders53
    Rodders53
    9 Oct 2019
    19
    Thanks Received:
    3
    Country:
    Quite likely the TV has got an analogue tuner but the VCR/DVD device was not connected and/or powered on when the TV first setup. It may be easy to add an analogue tuner scan or need a 'factory/shipping condition reset' to start gain (with the VCR on this time).
    I know my recentish Panny TV effectively hides/disables the analogue tuner when 'no signal found', but I could enable it from the menus... but can't recall how off the top of my head.
    :idea:If all else fails read the manual. Or search the internet for the answer.:sneaky:
  7. Sponsored Links
  8. Nozzle
    Nozzle
    23 Dec 2012
    2,134
    Thanks Received:
    276
    Suffolk
    Country:
    Get yourself an old VCR, or DVD recorder. They do it.
    Nozzle
  9. mattylad
    mattylad
    27 Apr 2008
    7,830
    Thanks Received:
    568
    Country:
    Given that what you want will cost circa £100 then its cheaper to get yourself a new DVD recorder (or is it a player you need?)
    And after that maybe you will have change for a new computer keyboard too :)
  10. Lucid
    Lucid
    10 Sep 2013
    1,688
    Thanks Received:
    975
    Cheshire
    Country:
    Like the rest of you here, I suspect that the likely reason Timothy is having issues is simply a set up thing. However, it's not going to be easy to help him until his posts are written in properly-formed coherent sentences, and there's some model numbers thrown in.
    We could all expend quite a bit of energy speculating and writing about potential solutions, and you're all free to do as you please of course. I'm not going to bother though until perhaps we next hear from Timothy. He has one post to his name, and since posting, we haven't seen him return so far.
  11. AsaGong
    AsaGong
    1 Mar 2021
    Thanks Received:
    Country:
    United States
    Hi...It's pretty rare for a VCR to have NO AV outputs on it of any type. Are you sure it has absolutely nothing else, aside from RF? Make, model, or photo of the back might reveal something.
    The route JayCee suggests will work if your recorder has an analogue tuner, but would not offer results as good* as using an AV connection of some sort.
Loading...
Share This Page
