However the spurs in question will be Fused Connection Units or FCU's
They have a fuse holder in them and the maximum fuse they will take is 13A, hence the 13A maximum
it can, but its not designed to. some sockets can take higher loads, others cant. sockets will be damaged if they are run at 26A (2 items connected at 13A each)
