Hi All
I was bought the el cheapo 4.5" angle grinder from b&q (PAG750A). I thought It would be Ok for the few needs I have for one. Unfortunately my research (or the b&q website) was not overly great.
So, I know it's cheap, I should invest in better etc etc. But the jobs are (were) small.
I want to cut concrete cast paving slabs. OK, so with a small grinder I'll have to go at it from both sides (finish is not important, the cut sides will be buried). Unfortunately I'm now looking at cutting 4off 600mm slabs in half (as opposed to just one) on my first job.
The operating manual says 'This product may not be used with coated abrasives or super abrasives such as diamond cutting wheels'
Why? From what I have read:
>Resin discs will take me all day and I'll need dozens of them.
>Someone suggested that diamond blades are thinner and it may cause issue with the disc mounting arrangement. I cannot see an issue in this respect with this cutter.
>A diamond blade might not work that well as the speed might not be up to it.
Apart from not being able to sue b&q when my arm is cut off, is there a good reason beyond 'cause it says so' that I shouldn't use a diamond cutter?
(I have full body covering ready, so I'm not a complete idiot
Cheers
Al
Cheers
Al
