angle grinder
17 Feb 2008
Berkshire
i have a small angle grinder with metal discs, can i get small discs to enable me to cut wood skirting
yes, its called a circular saw
but no you cant get a disc that fits an angle grinder that is for the purpose of cutting timber.
edited to add:
acording to the world of screwfix
thanks,
its just i need to cut a skirting from behind rad pipes to remove and replace with new. May have to stitch drill it i guess
You could use an arbortech disc, available from Axminster power tools..
Not exactly the most accurate tool in the world for cutting a straight line :lol:
if you're replacing it with new just chop it with an inch wood chisel if you don't have a mallet use a lump hammer to hit the chisel.
thanks, ended up drilling where it was behind pipes and a bit of force with a chisel, all out now!
