For some reason my original post on this topic has been locked, so I have no choice but to start a new thread as I would like to add some feedback.
Hi Ian, I followed your advice and set the pressure to 1.5 bar on a cold system (had to let some water out through the magnaclean to do this). I then removed the filling loop hose and turned the boiler back on. After an hour the pressure was at 1.9 bar and didn't increase above this. Unfortunately, it looks like the boiler overflow is still leaking, but slower than before.
I guess disconnecting the filling loop hose was to ensure it wasn't leaking and allowing more water into the system?
For the rest of last night, the pressures looked good, however, this morning we woke up to a freezing cold house and an F.75 error! Carefully let enough water in to clear the F.75 error but without over filling, so the digital gauge was showing 1.5 bar again. When operating, the boiler pressure is now between 1.7 and 1.9 bar, but the PRV is still leaking slowly.
I suspect as a result of the minimum amount of water being in the system and the leaking PRV, I will wake to the same F.75 error in the morning.
So, I suspect the PRV may require replacing and that may solve the issue? Tried to get in touch with my heating engineer today but without success.
I've also fired off an email to Vaillant technical support regarding the size of the internal expansion vessel and the size of my system just to get some indication of whether they think this should be rectified.
