- Joined
- 3 Jan 2005
- Messages
- 2
- Reaction score
- 0
- Country
I have a Ariston Eurocombi sx20 mffice. about 3 weeks ago I changed an isolation valve on a pipe external to the boiler as the previous one was starting to leak. I was told to switch of the boiler, turn of the mains water supply and drain the boiler to do this - so I did
since shortly after that the hot water would only come on if the central heating was on too. About a week later the hot went all together and it's cold showers all round
I know nothing about boilers so I really do feel at a loss at the moment so any advice would be most welcome.
If it helps at all when I turned the mains water back on I forgot to turn the valve that increases the pressure of the boiler off. The boiler wen't all the way up to 3 bar before I caught it. When I did, I turned the valve of and decreased the pressure to its normal level of just under 2 bar.
Daniel
Daniel
