I've trawled through loads of posts on this topic which have been valuable, but I have few specifics and would appreciate any advice out there pls.
1. Damp coming into a bedroom through an external wall. The wall is extensively covered on the outside by a climbing plant (Virginia Creeper I think). I think I know the answer to this one, but before I break the news to my wife that the plant needs to come down, is this likely to be a major contributory factor to the damp on the the inside of the wall? Also, the inside wall has been covered with some sort of polystyrene. Presumably this needs to come off as well in order to increase moisture evaporation?
2. The ground floor of the house seems to be generally quite damp (birthday cards 'curl' at the edges within a few days of being put out etc.). The cause of this is almost certainly coming from the cellar below, and I do have a long-term plan to increase ventilation etc down there, but with the imminent arrival of a new baby I need to do something more immediate. Would a dehumidifier be appropriate in this case? Is there a risk of 'over-drying' the structure of the house by removing too much moisture?
