Hi All,
I know that similar questions have been asked before but I have an additional query. I am changing my plumbing set up and had planned to use a fortic tank to supply a pumped shower for the main reason that I have very limited space. Now I can hear you all screaming don't do it due to the likelihood of running out the small amount of water in the header tank. However I am not on a mains supply and intended to pump the cold supply up to the fortic tank using a pump with a flow rate of 20l/min and using a shower pump with a flow rate of 10l/min in the hope that this would keep the header part of the fortic tank relatively full of water, would this work?
Any help appreciated!
Cheers
Andy
Cheers
Andy
