I have a Bermuda 401 back boiler with tasteful early 80's fire front. Recently it has started to make banging noises when the CH system is warming up, like its kettling, The noises started suddenly one day and now seem to be getting worse, although the CH system does warm up.
Now the bad bit!
I've had the front off and found that there is a small crack across the top of the burner, i.e the bit with lot of holes in where the gas come out. Also there seems to be quite a build up of combustion deposits, particularly on the Heat/ex. Basically its looking a bit sorry for itself.
I'm guessing my only solution is a new boiler, but it would be reet expensive to swap for a complete new combi system as my house has three floors, and I'm reet poor! can I get a direct replacement for the boiler and a new fire front, or will I have to sell my body to medical science and get a whole new system installed? I'm hoping to nurse it through the rest of this winter at least.
I am an engineer (hence the poorness), so there's no need to pull any punches.
Now the bad bit!
