Hi all, over the last two years the boiler has started playing up, after reading up about them, i was suprised it had lasted this long.
So far i have had the three way valve replaced, and more recently the pressure releif valve.
Now we have fitted some new taps (strange coinkydink) but the taps have a wider bore on them (where the water exits, not the pipes), but for whatever reason ( i have learnt not to understand this boiler) the water is starting to play up.
Right, here goes, not too hot with technical descriptions...
To run a bath, hot water would be nice, so turn the hot tap on, boiler pops to life, get hot water, hot water turns to cold. UNLESS you turn the water down to a trickle, it takes roughly 25mins to fill the bath!
The hot water dial is on max, and if when the bath is running (as it is now) i turn this down, the boiler stops, as expected.
So, what do i need to replace now so i can get decent flow of water, and it is hot?
Any help would be appreciated.
Mark.
Mark.
