I had some really useful tips about rawl plugs before. Our new house has a new problem.
The walls are plasterboard and behind that, block. The gap between the plasterboard and the block is too narrow to use those special winged fixings.
So far I have got round the problem by using really small rawl plugs just in the plasterboard, but I don't know if this will really be sufficient in most cases, especially if I am hanging something heavy.
I also once tried drilling through into the block, but this quite frankly was a nightmare and I ended up with a massive hole in the plasterboard because the drill moved a bit when I drilled the block, and just kept making the first whole bigger. I had to fill it in with polyfilla and it looked a mess. Thankfully I have hidden it behind a mirror!
Any ideas?
Any ideas?
