If you wanted to fit new boards by screwing them in, what do you call those drill packs that bore out a bit of the wood that you can fit to the screwhole afterwards and where can you get a good set? Also.. in my flat the doorways have a glass transom above therefore the whole fitting is full height, so the architraving is small/thin.. there's no room to fit anything wide. If i swop out the skrting which is also quite narrow i'd probably like something wider.. what's the standard practice for joining those where they meet the narrorwe architrave.. just notch a 45 off the top corner of skrting or something else? I'd be varnishing or staining so would want the most attractive or at least least attention drawing join..
