- Joined
- 26 Aug 2016
- Messages
- 6,830
- Reaction score
- 1,009
- Country
I agree with the above, it doesn't sound fail safe and wouldn't really be ok in health and safety terms
I don't know why I missed this at the time.Why? The load won't be going through the switch, otherwise, yes, I'd agree with you.
The solenoid is rated at 500 AMPS.
Just think of it as akin to starting a car, except the load isn't a starter motor, it's a 0.1 second pulse between two electrodes.
Surely this means it will only be delivering the same amperage as when cranking the engine
The current that flows when cranking a car engine is determined by the resistance of the starter motor winding and the opposing back EMF generated by the rotating motor. The arc at the welding site will not generate any back EMF
Back EMF Electro Motive Force ...... roughly speaking this is a voltage that is generated in the windings of the motor. It is the opposite polarity to the source battery,
Windings on a starter motor are about 0.05 ohms, cranking amperage is typically 300-400 amps.
A single coil resistance of 0.05 Ohms and 12 Volts applied results in a current of 240 Amps
nothing is going to happen to the battery.
It doesn't.Would it help if I pointed out the solenoid has a resistance of about 0.3 ohms?
It doesn't.
