So that will be (4 + 6)²? as clearly a square has two equal sides and the word 'and' is same as a + so 10m² is the answer, the point however is the answer will be some thing ² but the cm is not a ISO unit so should not be used anyway.
As to the question in this case, I would agree not straight answer however, anything which moves must have some parts which can wear, so more have a finite life, this life may be very long, however it must have a limit.
However maintenance is not limited to parts which wear out, clearly a pressure vessel must be tested at regular intervals, and electronic capacitors we know have a limited life. So looking at the question.
| Which one of the following micro-generation systems requires the least maintenance once installed? | |
| a) Micro-combined heat and power – These are in the main a boiler with a Stirling engine, and it does not state if the boiler is supplying a pressure vessel but many do, so we need it consider it will need a service once a year. | |
| b) Air source heat pump – These have been around for a long time, it does not qualify what sort of air source heat pump, if for cooling, heating, or both, or is a integral unit or has separate units, the main problem with the split units is the failure of the condensate scavenger pumps, which if they fail can bring a ceiling down, they are not required with heat only, but again one has to assume an annual service before each summer period. | |
| c) Biomass – These are solid fuel burners, and we must expect a build up of soot, tar excreta so must need the highest maintenance, OK user maintenance, but still maintenance so easy to rule this option out. | |
d) Solar thermal – This one must assume is the heating of domestic hot water, in theory these should run year in and year out without any maintenance, installed on a flat roof with the tank on stilts above the panels as done in countries like Turkey, these can run as my daughter well knows trouble free for years.
However in the UK these do not have tanks on the flat roof, so they need pumps to circulate the water through the panels, I know from my father-in-laws install they are prone to getting air locks should the pump not cut in at the correct time.
I think this is the option expected to have least maintenance, however in real terms it required quite a lot. | |
So we can rule out Biomass, but as to the other three it would require a study to see which required the most, and one must also consider number of maintenance personal, clearly if it required two people for safety then the maintenance is doubled. But as to the three systems in their basic form, i.e. with the Solar thermal installed on a flat roof with header tank above the solar array, this must require the least.
However this is a general engineering question, not an electrical one, as the Solar thermal has no electrical parts, also the Micro-combined heat and power may be a boiler with a Stirling engine, but could also be a generator with the cooling water being used as with most narrow boat installations.
I know there is a piece of string down the centre of a cable, so the answer to how long is a piece of string is equal to one tenth of a nautical mile, however a nautical mile is not a fixed length, it depends where one is, as the earth is not round like a ball, and when flying a nautical mile is longer than when in a boat, so the question is like asking how long is a piece of string. 185 to 241 yd is quite a big variation.
As to RAE showing ones age, it does not exist any more, my son passed it and he is 46 now, it was not long after that you needed to take three courses with marked course work to get licence, so much quicker with an exam.
