plus the drilling of numerous joists
There are strict controls & Building Regulations governing where & by how much you can drill/notch joists;
http://www.eastdevon.gov.uk/bc-guidancenote7-notchingofjoists.pdf[/QUOTE]
Hence my original question....... and sarcastic answer regarding drilling joists
How about the use of a non return valve? Or is that a definite no. Building regs etc...
Read & understand the Building Regs & what you can & cannot do before you go any further;
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADH_2002.pdf
Or call in someone who knows what they are doing!
Or maybe I ask someone who knows rather than someone who's only apparent skill is to post web links.
And not even the correct links either.....
Try this one instead next time -
http://www.planningportal.gov.uk/uploads/br/100312_app_doc_G_2010.pdf
A call to BC has established the following
Building Regulations: Part G permit the installation of a macerator only if there is access to a gravity discharging WC.
With the waste water from the toilet needing to go to a convenient foul water drain, therefore the shower/bath discharege pipe can be used but the installation of a non return valve on the pipe work of the bath/shower to stop the toilet water from returning up the drain of the shower/bath.
Building Regulations: Part P state that if an electrical installation involves running new cable work in a kitchen or bathroom, then it must be reported to Building Control and carried out by a competent person registered with the Electrical Regulating Authority, or checked by someone who is registered with them.
Comments like
No one can wave a wand & “make it happen” for you, there is always “a way” but it might not be easy or very cheap, which is probably why there wasn’t a bog in there in the first place. If you’re not prepared to fork out the cash to do it properly, forget the additional bog & stick with the shower room; you could always buy a chemical loo & stick that in there.
Are not at all helpful. I thought this was supposed to be a DIY resource forum not "let me pay someone else to do it for me" forum it appears that you may have joined the wrong site.
Who in their right mind would even suggest installing a chemical toilet in a house - Don't judge everyone else by your own level of incompetence.
So to rephrase the question would you recommend a anti-syphon or a hepVO trap to prevent the possibility of any syphonage occuring when the macerator operates?
