Antique blown wallpaper source
5 Jun 2009
Merseyside
I have some lovely old pressed / blown patterned wallpaper which is on the ceiling above my stairs - but similar to stuff below the dado rail -
it is damaged and I need to replace about 3/4 metres . Where can I find a range of old wallpapers so maybe I can match it ? It is an impressive pattern and will be hard to patch unless someone knows where I may find it ??? All help appreciated
How long has it been on? did you put it on or was it on when you moved into the house. A lot of older houses were papered with Lincrusta, heavily embossed paper made with putty. A lot of the patterns have been discontinued now but Crown still do some.
am guessing it is 40 years old . well before my time! Don't think it is made with putty, is just paper. will check crown range thanks.
Anaglypta :?: that was around 40 years ago. There is an Hotel in Eastbourne with a corridor dado of Lincrusta or similar. With Swastikas all along it :shock: embossed in the paper. Obviously before 1939 then :wink:
