I recently bought a new home (1930s semi) and keep finding things to worry me. I wonder if anyone can advise on the issue below.
There is an interior solid wall, presumably brick and load-bearing. It seems to be slightly uneven / out of plumb -- see the picture with the spirit level. I am very worried about this.
https://imgur.com/a/nJXnGVm
I wonder why it is happening. Is it likely to have to do with previous owners who completed building works -- double door partition between kitchen / living room, chimney breast removal, concrete roof tiles that impose a heavier loading. We weren't able to get building regulations for these (and I'm not even sure that my solicitor asked for them).
Please look at the picture of the partition -- should there be evidence of an RSJ here?
I had a Homebuyers Survey done. They advised: "an opening has been formed in the partition wall between the reception room and the kitchen. Whilst there is no evidence of significant cracking to the areas adjacent it is not possible to conform that adequate support is
provided. Your legal advisor should verify that local authority approvals were obtained for alteration."
"The chimney breast appears partly removed. Whist there are no signs of inadequacy, e.g cracking it is not possible to determine if adequate supports are provided. Your legal adviser should ensure that local authority approval has been obtained for the alterations."
"There is some distortion and cracking evident to the purlins but this is not felt to be of significance at this stage. It should be noted that the tiles are not original to the property and therefore will impose a greater loading. Although any distortion to the roof structure is not felt significant currently, it is recommended the timbers are monitored and if you should note further distortion further investigations will be required."
