I'm planning to construct a platform, hinged at one side, over the steps leading down to my basement. The platform will be surfaced with 15mm OSB and used to store bicycles as there's no-where else available.
I was thinking to make the framework out of 30mm steel square section tubes; just a frame with a few cross members:
ASCII ART: (should be in Courier)
Does anyone have any suggestion as an alternative to welding? I was thinking of cutting fillets from sheet metal and screwing or riveting them on, as moth of the rigidity will come from the OSB I think this is sufficient.
As I'm outside the UK I don't have access to all goodies available in the UK but might be able to find something suitable. The hinges would be installed along one of the long sides.
PS the ascii art was made here: www.asciiflow.com/#Draw
Many thanks...
Many thanks...
