Any Ford Experts??? - Central Locking help
F
Fordfan101
Hey all.
My ford escort (96) central locking system isnt working - the divers side rear door was jammed - but i released this using a test lamp n connected to a live wire.
I was installing a remote central locking kit and when i pressed the button something "popped" - i;ve no idea what!
I've pulled the Central Locking Interface box out to check - theres no relays on it - so it must be somewhere else...
Is there a test i can do to make sure the solenoids are ok? - theres 6 wires on the multi-plug and no idea which ones to conect to battery to test with.
Any advice pls pls.
F
Fordfan101
Found a link to another site - someone had similar problem on a mondeo.. so tried their trick and its all up n running!
Turned out to be a "hidden" fuse.. had to rip out the fusebox to locate it!
End Post
