Thanks for all the answers to my previous posts, you really have made the difference and given my confidence to continue with my DIY.
I've completed a load of new pipework this past week, and not got any leaking joints. Is it as safe as it'll ever be to start screwing down floorboards, boxing in pipe work, and redecorating? I'd assume that if you're not seeing a weep from a new compression or pushfit joint after 30 minutes then you're good? To be safe I'm giving the joints days.
Besides leaks (or rather the absence of), is there anything else to check before boxing stuff in? Do I need to worry about the plastic pushfit pipework I've added having some play to it (or must it all be rigidly clipped to the wall every x mm)?
