has anybody fitted the new baxi yet. sounds good with the 5 year warranty ?
Done a few netatecs, nice and light and compact. Stupid position of the test point on the gas valve the control panel doesn't stay up and the ignition lead pulls out if you lean on the panel..
Jig is sh#te if the wall is uneven and if in tight spot close to floor connections are a nuisance.
Gauge is in a silly place but no need for it as it is displayed on control panel anyways.
Flue will need one person in and one out to push into place unless you make hole big enough to drop into place.
Few wee niggles with it that need getting used to .
Found the netatecs jig to be dreadful,don't like pressure gauge position.
DO NOT turn the boiler on electrically until you have both the gas at the boiler and the system filled.
Lockout if you do, and it's debatable whether you can get it out of it.
