Anyone familiar with these shower panels?
I've bought these and they are on the way.
I'm after a bit of advice to the fitting of them. My shower has three walls and will have a glass door at the front.
Once cut to size, would you do the rear wall first? I was thinking of cutting this panel to size, attaching the two internal corner trims to each side and putting in place.
Problem is there is no room for manouvre if it is cut to exact size. The left handside has the shower pipes capped off, so I cant lift into place straight on as the caps protrude.
Also assuming I can angle this in, I was going to do the leftside next cutting the holes for the pipes but again there will be no way to slide it into the corner trim. Right side will be ok!
Secondly what would you use to stick to the wall? Silicon? Tile adhesive?
did you buy the 1s in my link or yours??
they also do joining strips etc.
ask them for the info required,like anything it depends on the state of your walls your attaching them too?.
Attaching to plywood shower cubicle. Old tiles and adhesive removed and sanded.
I have some mapei shower tile adhesive (was originally going to tile). Would that be any good?
