Just make sure that your hole is deep enough, put plugs in, put pan in place and plastic liner in hole in pan. Screw nut onto threaded part, put screw through pan and into plug then screw it into plug till tight.
never seen a pan fixing kit that uses screw bolts before. Are they just plastic nuts?
2 usual kinds of fixing kits these days, depending on the toilet. Side fixing with plastic L brackets or top down fixings with screws and caps for old school screw down through the pan.
