Anyone used Helifix crack stitching products?
20 Mar 2006
About to use these products to repair some cracks in some external masonry, although I've not used them before, the process looks very straight forward. I've got a 4.5lt tub of the 'special Helifix grout', cost about £50 + vat, but a bit surprised it looks to me like a bag of OPC and a sachet of PVA! Now I'm sure Helifix would say they're 'specially formulated' materials, but sure looks to me like I'm being tucked up!! Anyone have any opinions on this?
Oh good. Another topic about someone's paranoia about being ripped off. :roll:
What, exactly, is the building problem you want help in solving?
It's actually an epoxy cement grout, not normal OPC. But yes, probably cheaper as a standalone packet.
The other big cost are the SS helical bars.
If you could source the items individually elsewhere, then
could be a bit cheaper.
Wouldn't touch twistfix with a bargepole. Target fixings much better and cheaper - followed by Helifix.
I use helifix all the time an iv used twist fix and id say helifix hands down
crack stitching with the helirods an helifix is peace of cake be shore to wash out the cuts...
use the compound just add the white liquid to the powder an mix with a small mixing paddle in a drill slow speed to start with.
use the mortar gun to pump in the compound then poke in the rods an add more compound over the rods an jound off with pointing iron
resin bond gear isn't cheep for a reason its **** hot gear
try an get a helifix registered installer to quote the job your wallet will grow legs an run away lol...
I install loads of helifix gear from ties crack stitching to lintels
Do you still do these kind of jobs ? Please let me know.
Thanks.... I did note that... I understand he hasn't posted anything for years... But i am just giving a try.
