anyone?
4 Mar 2010
I have a hot water copper tank in my ground floor bungalow airing cupboard and a worcester greenstar boiler in the kitchen (not combi)
The problem I have is since buying this place 2 years ago is the extremely slow running and low pressure from just the kitchen tap. Even without a tap fitted to the sink the hot flow is the same and I'm almost convinced the mains cold is not as good as it could be.
The cylinder/tank is 2 meters away from the bath / bathroom sink taps and is fine in flow and getting up to temp, very hot is 15 seconds max . The kitchen tap is 10 meters away and it takes at least 2 mins to get hot and the flow is laughable. The kitchen sink is in an extension built years ago and following the route the galvanised cylinder/heater pipe goes into the concrete floor and appears under the kitchen sink as a flexible plastic pipe.
I still have not laid the tiles in the kitchen so what's the answer?
Dig up the floor from the tank to the sink to lay new pipes?
Clean out the pipes- is this possible?
A pump? what would I need?
ANY advice would be VERY appreciated, this is doing my head in?
Is there a filter/aerator on the spout that needs cleaning
Galvi pipes still in?
Replace them as they do block up and you wont clean them
It's same crap flow taps fitted or not.
Your system seems to have a minimum head from a loft tank giving insufficient head to provide enough flow to the kitchen.
You might get a small improvement raising the loft tank but to solve the problem you will need a pump!
Tony
