Apha combination boiler problem
31 Aug 2013
Wiltshire
My plumber has given up and told me I should call out the Alpha engineer at a one off cost of £300. My problem is intermittent hot water, no problem with CH. if I override and switch the CH on, I get hot water, although not as hot as when the hot water works without the CH on, which it does occasionally.
The most consistent tap is the bathroom, which is closest to the boiler. Those furthest away, kitchen and utility rarely work.
My plumber has changed diaphragm valve unit and pressure switch.
Is now suggesting PCB but really has not got a clue
Any engineer in Chippenham able to help - please!!??
Many thanks
Bazzer
Please start your own post with your problem, yours is a different problem to this post if you Hi jack a post you will get the wrong advice
Without model details I can't advise much.
I do know the Alphas have a stupid flow switch on the water main inlet. I don't work on them much but has your plumber checked this?
If you provide model details you'd get more help.
Thought i put model in the header - sorry
Alpha CB24. He has changed that switch.
I have put this as a separate item on the forum as apparently I am not supposed to hijack other posts
