curently renovating a bedroom.
Most of the artex ceilings in the house are ok, so I've not needed to cover them.
However, in the room I'm currently doing it looked like the previous house owner had gone through from loft and it been patched up and left uneven in an area.
So after applying diluted pva, I put a tight coat of Bonding on first to smooth it out a bit.
I'd left the Bonding 3-4 hrs and was probably about 25% dark at the point I skimmed. Was getting late and I needed to finish same day.
Had a few blisters even during smoothing the first coat. A few more when the 2nd coat went on.
I generally didn't do too much troweling up in those areas to not make it worse and am left now it's set with about half a dozen, in a pretty good ceiling. I'll give them a rub down and apply a little easifill if needed, which will do for me.
In the interest of improving for next time - any good ways to handle them whilst plaster still setting?
