I am getting some building works done to my residential home in 3 areas of the house. Wanted to know an approximate bracket or best estimate I should allow in my budget for the following work to be done. I know its difficult to tell without seeing the rooms in question, but if someone would be able to provide an approximation, it would be greatly appreciated. I can provide further information if required. Currently, the lounge area has been finished to concrete slab level only (no insulation or screed). I am getting a separate gas safe engineer to run the copper pipes for water and heating / install new boiler etc at a suitable time which I have received a quote for.
kitchen floor area = 26.1m2 (9.1m x 2.9m)
lounge floor area = 26m2
hallway floor area = 3.5m2
Total floor area = 55m2
- Dig out kitchen and hallway to depth of least 500mm and remove all waste
- Hardcore bed compacted at least 100mm, sand blinding for smooth base, 2000 gauge toughmax dpm, concrete slab minimum 150mm depth, 100mm celotex insulation, 100mm concrete screed minimum 75mm thickness
- Connect drainage from 1st floor ensuite to drainage under kitchen floor.
- Install extractor fan in plaster board ceiling of under stairs toilet, leading out to side of Bed 3 wall
- Put rockwool or celotex insulation between ceiling joists for kitchen / lounge / hallway
- Take down kitchen ceiling and replace with new plasterboard ceiling.
- Plasterboard lounge and Hallway ceiling area.
- New kitchen electrical sockets (including 40A cooker switch, new lighting wiring with switches, connect to main consumer unit.
- New Lounge and Hallway electrical sockets (new lighting wiring with switches, connect to main consumer unit)
- Install new spotlights / 2way switches
- Skim new Kitchen / Lounge ceiling.
- Fit cavity closers / boards around windows in Kitchen / Lounge / Hallway area
- Cement render kitchen walls over block/brick work and skim finish.
- Cement render and skim finish Lounge and Hallway.
- Lay tiles in Kitchen Area. Lay tiles in Hallway area.
- Fit tiles to window sills in Kitchen / Lounge / Hallway area.
- Fix 2 new wooden doorframes for entrances into kitchen area.
- Run 28mm gas pipe to new boiler location (5m away from existing gas main) and seal to allow new boiler installation.
Many thanks.
Many thanks.
