can any one help?
I am putting in an aqualisa quartz with fixed head - 3 questions....
I have run 15mm copper from the pump to the recommended 1/2in bsp female fitting which is secured to the wall - do I need to wrap the spigot (used to mate up to the shower head) threads with PTFE tape to get a decent seal, and is it OK to just hand-tighten into the bsp fitting? or should I have bought a tapered female fitting?
I'd prefer to have tiled first before fitting the spigot through the 18mm ply walls of the shower i.e. into a tiled+finished surface, but from the design of the spigot/+ particularly washers on the spigot - it seems it is only possible to attach it before tiling around?
also, what is now recommended height for the shower head above the floor of the tray?
any thoughts appreciated!
thanks
andrew
thanks
andrew
