Aqualisa Quartz remote button problem
28 Feb 2007
Oxford
Hi All,
just checking I'm not missing something daft with our new aqualisa quartz.
The main controls work perfectly, however the wired remote button doesn't do anything and the blue light on it is on permanently. Nothing changes on the remote button when you use the shower.
Plumber is at a loss as to what is wrong with our wired remote.
I've double checked the wiring according to the instructions, all seems correct
the wired connections are:
Remote to switch box
switch box to control box
control box to main control buttons.
I'm guessing we have a faulty button or cable but would appreciate any advice if anyone has seen this before...
Andy
Hi Andy
I assume you found out what the issue was?
I have the same issue after doing my install today. I am baffled and can only assume there is an issue with the cable as the button works fine on my other shower..
Let me know what your solution was
Cheers
Matt
