Aquapanel Board.
7 Oct 2004
Just a quick one, looking to rip out my old shower room and replacing the plasterboard in the shower area with aquapanel board.
A couple of questions:
1. what type of fixings do you use to fix to a battened wall
2. what type of fixings do you use to fix to a solid block wall
3. Whats best to filler to fill the joins with before tiling
And is this the best type of board to use? Is there alternatives?
Many thanks
This is an excellent product and works extremely well.....use plated csk woodscrews to fix to battens and similar with 6mm plugs direct to the wall. There is an adhesive by Knauf to stick the edges together and its not strictly necessary to use a filler if the edges are tight. In all cases, get the boards as flat as possible. Wickes supply what you need.
John :)
Great, thanks for your advice.
Sorry just a couple of questions
1. Could I just not tank the existing plasterboard, would this be ok?
2. Someone mentioned Hardie board, is this better than aquapanel?
3. If I do use aquaboard/hardie board, would I need to apply a tanking kit for this?
Thanks again
Apprecaite your advice
Plasterboard is a pretty horrible medium in a wet area......all is fine so long as there is zero water penetration!
Personally I think the plasterboard should have a tanking solution applied - others may disagree - but aquapanel doesnt need it as its waterproof anyway, or rather it can absorb water without disintegrating.
As far as I know, Hardie and Aqua are one of the same......cement based boards perfect for tiling.
John :)
I prefer hardibacker as it doesn't crush at the edges when screwfixing it onto studs.
When dot and dabbing it to solid walls I pva the back just prior to installation.
Thanks again for your help. Ok, will get the correct fixing and the adhesive for the edges.
On their site it mentions it should be primed with their own primer, I cant seem to find this anywhere but is this the same as any plasterboard primer so I could use something like this https://www.toolstation.com/mapei-p...MIy4bEiIjI4wIVQbDtCh2zeAVnEAQYASABEgIc3vD_BwE
If it was you would you tank it as well?
Many thanks
Hi Guys, just wondered if anyone had any views on this, is this the correct forum for the question?
